Community Member
Help needed
am trying to configure HSRP.Currently am using 4 switches ,2 Nos -6509,2 Nos-6513.Trunking is enabled between the 6513 switches, also the trunking is enabled between each of 6509 and 6513..
HSRP is enabled on 6509 switches.i have connected PCs to the switches.But when i ping from end to the other,its not successful.Should i have to give the standy ip address as the default gateway in the PCs.
PC1 6509 6509 PC2
6513 6513
any assistance would be appreciated...
Re: Help needed
The IP Address you provide with the standby command should be the
Default Gateway Address on your PC's.
Do also a clearing of the arp caches.....i could be that you still have old
entries in the caches.
Community Member
Re: Help needed
Hello Roger,
Thanks for your suggestion.I need to clear one more point on "show standy " command.
When i see the "show standby"command output in the active router,
Router#sh standby
Active router is local
Standby router is x.x.x.x expired
x- denotes the IP address,but the IP address shown is the active routers IP address.actually stnady routers IP address must be displayed.
any idea.
Thanks well in advance..
Community Member
Re: Help needed
With HSRP, you do use the standby IP Address for your computer gateways. The Standby IP Address is the only IP Address that the HSRP devices all listen to for failover.
Re: Help needed
You're right. Typically, the standby router's IP should
be displayed or when the peer is not recognized, it
usually shows "Standby router is unknown expired".
The problem might be affected by the HSRP timers.
Re: Help needed
Thats correct you should see the hsrp neighbors address.It should look about like this:
Router#sh standby
FastEthernet0/0 - Group 101
Local state is Active, priority 100, may preempt
Hellotime 3 sec, holdtime 10 sec
Next hello sent in 0.416
Virtual IP address is configured
Standby router is expires in 8.024
Virtual mac address is 0000.0c07.ac65
53 state changes, last state change 2w1d
IP redundancy name is "hsrp-Fa0/0-101" (default)
Priority tracking 1 interface, 1 up:
Interface Decrement State
ATM2/0.2004 10 Up
Anyway do use a group like in the sample above the group 101. You could also implement it without a group.
As somebody also has writen it could be also a timer or authentication issue.
Hope that helps you.
