Help on Debug
Hi Friends,
I am getting the below error messages in my ROuter Logs.can any one help me explain me and give a solution for this.
2d04h: %AMDP2_FE-3-UNDERFLO: Ethernet0/1 transmit error
2d05h: %AMDP2_FE-6-EXCESSCOLL: Ethernet0/0 TDR=1, TRC=0
Re: Help on Debug
While transmitting a frame, the local buffer of the controller chip received insufficient data because data could not be transferred to the chip fast enough to keep pace with its output rate. Normally, such a problem is temporar y, depending on transient peak loads within the system. The system should recover.
Ethernet or Fast Ethernet is detecting multiple collisions. This condition may occur under heavy loads. The system should recover.
Refer the following site for information
http://www.cisco.com/univercd/cc/td/doc/product/software/ios112/fgemf.htm
-Deepu
Re: Help on Debug
hank You all for the Valuable Responses.
Rgds
Srini
Re: Help on Debug
Hi there follow this link to the error message decoder , it will tell you exactly what the problem is if any:
http://www.cisco.com/cgi-bin/Support/Errordecoder/home.pl
The following is the feedabck from the decoder with regard to your error's.
1. %AMDP2_FE-3-UNDERFLO: [chars], transmit error
Recommended Action: No action is required.
Related documents: No specific documents apply to this error message.
2. %AMDP2_FE-3-UNDERFLO: AMDP2/FE [chars], Transmit underflow
While transmitting a frame, the local buffer of the controller chip has received insufficient data because data could not be transferred to the chip fast enough to keep pace with its output rate. Normally, such a problem i s temporary, depending on transient peak loads within the system.
Recommended Action: The system should recover. No action is required
Re: Help on Debug
For this warning message in console
For this warning message:
%AMDP2_FE-6-EXCESSCOLL: [chars] TDR=[dec], TRC=[dec]
The above 2 warning message won't affect your router functionality and performation and it should recover automatically.
Kiruba
240
