Webcast-Catalyst9k
Help on FEC
hi
i m trying to enable port channel but its giving error
Switch(config)#int port-channel 1
% Invalid input detected at '^' marker.
Switch(config)#
this is the output of my sh ver..of the switch.
Switch#sh ver
IOS (tm) C2900XL Software (C2900XL-C3H2S-M), Version 12.0(5)XU, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Mon 03-Apr-00 16:37 by swati
Image text-base: 0x00003000, data-base: 0x00301398
ROM: Bootstrap program is C2900XL boot loader
Switch uptime is 11 minutes
System image file is "flash:c2900XL-c3h2s-mz-120.5-XU.bin"
is this ios ver supports FEC ???
pls help on this
regds
prem
Re: Help on FEC
You cannot use the int port-channel command. Infact you have to use the port-group command.
Agnelo
Re: Help on FEC
hi agnelo
thks for replyin...
i m getting the option for port-channel when i give a command like this
TestSwitch(config)#inter ?
FastEthernet FastEthernet IEEE 802.3
Multilink Multilink-group interface
Port-channel Ethernet Channel of interfaces
VLAN Switch VLAN Virtual Interface
Virtual-TokenRing Virtual TokenRing
but i dont know why i m not able to enable them.i tried port-group under each interface where i can do the config for port-group becoz if i give portgroup in global mode its not taking it ...
regds
prem
222
