Webcast-Catalyst9k
Help on module selection
I have a line that is described as :-
Digital-2 Mbit/G.703 RJ45(120ohm balanced) to RJ45(120 ohm Balanced).
It is an E1 circuit.
I wish to put a 2600 router at each end.
What module do I require for this?
Thanks for any assistance,
Charlie
Re: Help on module selection
Charlie,
You might need 1 or 2 port VWIC-MFT-E1. Check this URL for more detail:
http://www.cisco.com/warp/public/788/products/vwicmf_e1.html
Bessie
If it's just for data, then the following modules will do what you want:
NM-1FE1CE1B, 1 FastEthernet, 1 Channelized E1
NM-1FE2CE1B, 1 FastEthernet, 2 Channelized E1
NM-1CE1B, 1 Channelized E1
NM-2CE1B, 2 Channelized E1
These modules will take up an entire slot.
The VWIC mentioned above can do voice and data on the same module and must be in an NM-HDV to terminate voice calls.
Clay
88
