06-11-2003 09:25 PM - edited 03-02-2019 08:04 AM
Hi Friends,
I am Facing problem with MRTG Config. any one pl. guide me on proceeding further.. here are the steps I followed on an NT Machine.
1. Configured SNMP Public string with RO on Cisco router.
2. generated mrtg.cfg file in mrtg-2.9.29\bin dir.
3. created www\mrtg is c:\ .
4. installed perl and is working fine getting the Echo Mesg from perl.
5. added new line to script on top enabling the runasdeamon=yes
6. IIS installed on NT.
7. what is the line for Current dir: " is it inetpub\wwroot\mrtg or the one created manually in c:\www\mrtg. here i am having a doubt. should i manually create
the folders or mrtg will create them automatically. Pl let me know.
ALso what is the url i need to type to get the graph interface wise on my roter.
looking expert guidance in this regard. I have gone through MRTG docs but some points are not clear thers. I am working first time on IIS. any one pl. guide me.
Rgds
Srini
06-11-2003 10:12 PM
Srini,
The mrtg.cfg file you just created should look similar the the following lines at the beginning of the file:
# Created by
# cfgmaker public@xxx.xxx.xxx.xxx --global 'WorkDir: c:\www\mrtg' --output mrtg.cfg
### Global Config Options
# for UNIX
# WorkDir: /home/http/mrtg
RunAsDaemon: yes
Interval: 5
# or for NT
Imagedir: c:\www\mrtg\images
That same mrtg.cfg file MUST have the following line at the end:
Hth,
Angel
06-11-2003 10:23 PM
Why don't you try your question on the MRTG mailing-list.
http://people.ee.ethz.ch/~oetiker/webtools/mrtg/forum.html
regards,
Martijn
