Help please with NAT on two private networks
Ok.. I admit it.. I am clueless.. Maybe that cisco cert would have come in handy right about now.. but I gave it the old try and now my brain is getting crispy trying to figure this out....What I have is two different LAN's that I need to join.. one is the 10.2.0.0 network the other is the 10.20.240.0 network.. both 24 bit subnets. Anyhow if you need to know why here is the situation.. the 10.2.0.0 network is mine.. the 10.20.240 network is a vendors that I want to get to from my 10.2.0.0 network.. so ... this enough babbling.. this is what I got, alot of it is the default stuff... I'm not concerned about security just yet, as both networks are pretty secure.. I just want all traffic to flow from one to the other and vice versa.
Critical info:
1) I can, from the LAN side ping both the lan and the wan port from my PC
2) From the router I can ping both ports, and I can ping anything on either side.
3) From my PC I cannot ping anything on the WAN side(cept the WAN port of the router).
4) When I issue "show ip nat translation" I get a blank line and thats it.
5) most important.. how do I remove lines from this thing.. all I can do is add lines :->
Cicso 802 router
Running like this:
ip subnet-zero
interface Ethernet0
ip address 10.2.0.9 255.255.255.0
ip nat inside
hold-queue 100 out
interface Ethernet0
ip nat inside
hold-queue 100 out
interface Ethernet1
ip address 10.20.240.100 255.255.255.0
ip nat outside
ip nat pool wannat 10.20.240.101 10.20.240.101 netmask 255.255.255.0
ip classless
no ip http server
access-list 101 permit ip any any
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
I'm assuming it's my ACL I made, or maybe some default ACL thats running, but the manual that came with the router(I know.. cisco cert would be a good idea) but it's in greek or something. Sooo, if you can please help.. my code is below..
Thanks for your time
Josh
jmartin@motorwerks.com
Hey.. at least I managed to turn the thing on!!!
1 REPLY
Re: Help please with NAT on two private networks
you're missing one line.
'ip nat inside source list 101 pool wannat overload'
Without this line, you can't have translation.
86
