Help reqd in BGP config
hi
we hve bgp peering with 2 diff isps .ISPA/ISPB.
our main goal is to have load balancing,redudancy.
we have configured the routers to meet the same conditions.but right now the load balancing is happening but reduandcy is not working i.e., if one link goes down out of 2 our browsing strucks up.
i hve pasted the current config out here.
pls take sometime to go thru it and advice..
router bgp selfAS
no synchronization
bgp log-neighbor-changes
network s.s.212.0
network s.s.213.0
network s.s.214.0
network s.s.215.0
network s.s.216.0
network s.s.217.0
network s.s.218.0
network s.s.219.0
network s.s.252.0
network s.s.253.0
network s.s.254.0
network s.s.255.0
neighbor a.a.a.a remote-as isp2AS
neighbor a.a.a.a ebgp-multihop 5
neighbor a.a.a.a update-source Loopback0
neighbor a.a.a.a weight 1000
neighbor a.a.a.a soft-reconfiguration inbound
neighbor a.a.a.a distribute-list 6 in
neighbor a.a.a.a route-map bi out
neighbor remote-as isp3AS
neighbor b.b.b.b remote-as isp3AS
neighbor b.b.b.b soft-reconfiguration inbound
neighbor b.b.b.b distribute-list 20 in
neighbor b.b.b.b route-map bbbb out
no auto-summary
ip default-network b.b.6.0
ip default-network b.b.1.0
ip default-network a.0.0.0
ip access-list standard bbbbb
permit s.s.219.0
ip access-list standard bbbbpill
permit s.s.255.0
permit s.s.254.0
permit s.s.253.0
permit s.s.215.0
permit s.s.214.0
permit s.s.213.0
permit s.s.212.0
permit s.s.218.0
permit s.s.217.0
permit s.s.216.0
permit 203.201.192.0
permit 203.201.193.0
access-list 6 permit a.0.0.0
access-list 20 permit b.0.0.0
access-list 20 permit b.b.1.0
access-list 20 permit b.b.2.0
access-list 20 permit b.b.6.0 0.0.0.255
access-list 21 permit b.b.b.b
route-map bbbb permit 40
match ip address bbbbpill
route-map bbbb permit 50
match ip address bbbbb
set as-path prepend selfAS selfAS selfAS
route-map Check permit 25
route-map bi permit 30
match ip address ispa
prem
Gold
Re: Help reqd in BGP config
Your configs look fine--if you're load sharing, then both links, and both BGP sessions, are working fine. When you have one link failed, do new sessions work? Do the routing tables look right with one link failed?
It could be that when you fail one link, a given session (HTML browasing session?) happened to be going across that link, and the browser may not like the lenght of time it's taking for the network to converge on the single link, or TCP may be resetting, or something along those lines. Could you describe what you mean when you say a browser gets "stuck"?
Russ.W
Hi russel
c once my ispa fails all the incoming as well as the outgoing shuld go via ispb which is not happening at present.i m unable to login yahoo and some(notall) international sites when ispa fails.
wht may be the problem ??
thx
prem
Bronze
Have you coordinated this configuration with both ISPs to ensure that they're accepting all the prefixes you're announcing? If some sites work via ISP-B but most don't, this could indicate that ISP-B isn't announcing your prefixes to all of its neighbors for some reason.
I'd suggest initiating a failover to ISP-B and then running some tests to get a better idea of what is happening. Tracerouting to various destinations might be helpful to determine where the problems are occuring. (Are the traceroutes stopping at your router or somewhere in ISP-B's network?) Getting ISP-B involved in the troubleshooting may also be helpful. They'll be able to check their routers to see if your routes are propagating correctly.
prem, I am having teh same problem. Were you able to figure out what's wrong? vikrant
what does the network look like when the link to your primary ISP is failed ? Do you still have the full BGP routing table, is the next hop address correct ? If you log onto an internet route-server does your prefix appear in the routing table ?
thks all for u r replies.
i checked with ispb with whom we r creating neigbhoship with our WAN IPs(with ispa we r doing with loopback) as per them they r announcing all the routes to us.
but still i m unable to fix it up.i cant do any experiments with the live n/w will do it in off peak and let u know edwards.
prem
There are two possibilities here.
1. Your upstream ISP may have problem because you advertise your network as /24 (maybe one of them aggregating it for you, the other did not). Try aggregating them in your core router. Add the following lines in your BGP configuration
aggregate-address s.s.212.0 255.255.248.0 summary-only
aggregate-address s.s.252.0 255.255.252.0 summary-only
2. I see that you have eBGP multihop, does the connection problem surface only when you left with your eBGP connection with ISP2AS. eBGP Multihop peering if successful will receive all BGP route but will not be able to reach the destination if the routers between you and the ISP2AS does not have Internal routing protocol to reach those destinations. I have experience this in both Lab and Production.
Example;
YourRouter>R1>R2>R3>R4>ISP2AS = 5 eBGP Multihop, right?
If using static route,
R1 to R4 should know that 0.0.0.0 0.0.0.0 (the Internet) is via ISP2AS.
R4 to R1 should know that s.s.212.0/21 and s.s.252.0/22 is via YourRouter
YourRouter
ip route BGP_IP_OF_ISP2AS 255.255.255.255 R1
R1
ip route 0.0.0.0 0.0.0.0 R2
ip route s.s.212.0 255.255.248.0 YourRouter
ip route s.s.252.0 255.255.252.0 YourRouter
R2
ip route 0.0.0.0 0.0.0.0 R3
ip route s.s.212.0 255.255.248.0 R1
ip route s.s.252.0 255.255.252.0 R1
R3
ip route 0.0.0.0 0.0.0.0 R4
ip route s.s.212.0 255.255.248.0 R2
ip route s.s.252.0 255.255.252.0 R2
R4
ip route 0.0.0.0 0.0.0.0 ISP2AS
ip route s.s.212.0 255.255.248.0 R3
ip route s.s.252.0 255.255.252.0 R3
ISP2AS
ip route BGP_IP_OF_YourRouter 255.255.255.255 R4
Gold
One thing you can do is to check one of the looking glasses to see how your routes look when the first ISP goes down. In fact, I would check the looking glass and see what it looks like normally, then check it in failure mode, to see what the difference is.
http://lg.conxion.net/
Is a place where you can search various exchange point and provider BGP tables to see what your route looks like as they see it.
Russ.W
105
