Webcast-Catalyst9k
Help Required for a technical issue
Hello there
Well I am a new CCNA and am facing a technical issue. One of my client has a cisco 2500 series rounter from which he is connecting a server then the server goes to a switch, which distributes data and internet connectino sharing to the local network. He has got a 64kbps leased line from an ISP, now he wants to take another 64 kbps from a diff ISP and wants to club both the bandwidth and give his local network a through put of 128 kbps.Is this possible through the router.
Pl if anyone can help me out
Devang Parikh
1 REPLY
Re: Help Required for a technical issue
Hi Devang,
you can use both the links in load balancing mode.
do the routers have any dynamic routing protocols configured????
you can achieve load balancing using static routes also.
-Sai.
95
