You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
help required for LAN with Multiple secondary IPS
Hi all
i have 2500 router, which is connected to my back to back with my core router
now i have only 1 ethernet, wich is connected to 8 port switch
i have 5 customers, with adsl with LAN termination to 8 port switch
i have added all 5 address to secondary to ethernet
not i have problem with if some one know the IP address and they keep that block, other customer will not been able to get connection
and i want the router not anouce other routes to other customer
how can i achive above setup
core router------2500---lan----cusotmers
thanks
hari
  • Other Network Infrastructure Subjects
1 REPLY
Re: help required for LAN with Multiple secondary IPS
From what I understand from your question, it seems that you do not want to advertise routes of one customer to another customer. Split-horizon will automatically stop advertising routes learned via an interface, out of the same interface. You can use the following link to get more information about secondary addressing and routing updates. If the routes are still being advertised, you can use the 'distribute-list' command to filter the routes.
http://www.cisco.com/warp/public/105/41.html
http://www.cisco.com/warp/public/105/34.html
85
