07-08-2002 09:53 PM - edited 03-01-2019 11:43 PM
I have installed Cisco Works 2000 with RME and Campus Manager on a Windows NT4.0, SP6a server with PIII 866 MHz and 1 GB RAM. But when I try to access through the browser client, the performance seems to be drastically slow. Also I cant find any installation problems. Can somebody advise?
Raj
07-09-2002 09:12 AM
What is the version of RME and web browser that you're using?. IE tends to be a bit fast than Netscape. Also, is the performance same if you access CW2K from the server itself?. When you say performance is slow, how slow is it?
07-10-2002 12:07 AM
I`m using RME 3.2 with CW2k CD one third edition ,and the browser version IE 6.0. The performance is same ,if I access the CW2K from the server itself.For loading a page,it takes about 3-4 minutes exactly.
Raj
07-10-2002 08:10 AM
Have a look at the the task manager in NT. Is the processor running at high levels (if so, which processes?), how is the memory utilization?
Also, make sure you have installed jre 1.3.1 & that your jvm is a recent version. IE5.5 always works well for me.
Also, is your server correctly configured in your DNS (if you are using DNS) ?
07-10-2002 09:03 PM
Hi:
Following are the processes that uses maximum CPU and memory . The CPU is getting utilized an average of 70-75% and the memory usage is an average of 40-45%
dbsrv6.exe
cwjava.exe
As you suggested the system is running JRE 1.3.1 and latest version of JVM.
We are not using DNS.
Please advise.
07-11-2002 07:31 AM
It is difficult to know how to progress this.
I have never seen CW2K running that badly on a correctly configured and spec'ed server.
I can only suggest you make sure you have all OS patches installed and maybe re-install CW2K if you are sure your OS is running OK..
.....Sorry.
07-12-2002 02:58 PM
I have experienced this and Cisco site recommends only accessing RME through a web client and not directly on the server i.e another machine. I have also resimulated this with CWorks on VMWare and this seems to work.
