help required to configure a 801 ISDN router and remote PC
I have little experience with cisco routers, but have been requested to connect a remote PC with an ISDN card to a corporate LAN, I have an 801 router on the corporate LAN available for use but have never configured one before to do this - neither have I configured a remote PC to access a LAN with an ISDN card!!! I would appreciate an idiots guide on how to do both sides of the connection and a sample router config if poss. if anyone knows of a good book describing such a connection, that would be useful too. thanks for any help.
1 REPLY
Re: help required to configure a 801 ISDN router and remote PC
Try searching on 'isdn configuration guide' on CCO. You might also want to add your IOS release to the search string. Conversely, go to this link and select your IOS. Then narrow it down to ISDN and/or dial solutions.
http://www.cisco.com/univercd/cc/td/doc/product/software/
As for a book, Cisco Press has several that address the issue. Perhaps "Building Cisco Remote Access Networks" might be a good one (I own it but haven't gotten around to reading it yet).
Check out bookpool.com for about the best prices anywhere.
110
