help !! router can't entry via super terminal ?what's wrong ?
My cisco 2611 router is running nomally ,via tftp may entry ,but cann't entry via super terminal of computer ?
What's wrong ?
Re: help !! router can't entry via super terminal ?what's wrong
hi
You mean Superterminal here as the telnet application or using hyperterminal connection ??
do revert how ur using or steps used to access via superterminal..
regds
Which OS r u using.Can u tell the exact software(ought to be HyperTerminal in there)
Are you trying to get in through console?
JD
103
