Help setting up ssh (putty) in 2821 routers
I am trying to use ssh for the the 2821 routers. They have IOS 12.3(11)(k9) on it.
So, these are the steps that I do:I add a new user name with no AAA model. And I give the user name privilege level 15(I also gave it 0, but nothing). The routers already have a hostname, and I add the domain-name. So After these commands, I create the key, using crypto key generate command.
So after this, I go into putty, type the ip addres, set-up for 3des encryption.
I am able to make a connection to the router, asking me for the login name and password, but when I typed the username and password, it response, "Access Denied"
any comments or anything will help. Thanks
Green
Re: Help setting up ssh (putty) in 2821 routers
Try using SSH Version 1. Most of the "older" Cisco hardware / IOS can only connect with Version 1.
SSH1 has been broken, but it's still much more secure than Telnet.
Good Luck
Scott
What's the default username and password for SSH in Cisco routers?
Haitham
AFAIK i dont think you got to have a default username and password concept for SSH instead you need to manually setup the username and password using the cli config command.
regds
878
