Help: Switch port with errors
mirtenmous
Yesterday a gigabyte port of 3750 catalyst switch was down suddenly, I did a shut and no shut and this port retrieve connection. Now, I am researching what happened and I can see in show interfaces output of this port the following:
Hardware is Gigabit Ethernet, address is 0014.69bc.0f9c (bia 0014.69bc.0f9c) MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLX SFP
input flow-control is off, output flow-control is unsupported
Last input 00:00:16, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1780930 packets input, 257622708 bytes, 0 no buffer
Received 58460 broadcasts (0 multicast)
163 input errors, 6 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 50188 multicast, 0 pause input
5486637 packets output, 606356394 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
I can see 166 input error and I don't if it is important.
Anybody can help me to troubleshoot this port failure?.
Thanks.
11 Replies 11
lgijssel
Level 9
Level 9
This is a sinfle mode fiber link.
You should not see too much input errors there.
Possible causes:
input signal either too high or too low
faulty SFP (mostly on the TX-end)
damaged fiber patchcable
regards,
Leo
Kevin Dorrell
Level 10
Level 10
I think this is an indication something is wrong. Personally, I start investigating if the error rate on a fiber link goes above a couple of parts per million. Normally I expect a fiber link to show zero errors.
I would start by replacing the GBIC of the equipment at the other end of this link. In my experience that is by far the most likely point of failure.
Kevin Dorrell
Luxembourg
spremkumar
Level 9
Level 9
hi
can you check out for possible error logs with respect to this port ?
that might give some clue on what might have gone wrong or the reason behind the port going down...
regds
Hi.
I saw error logs with Cisco network assistant and this interface is the only one that have fcs errors (6 errors), also have few packet errors.
For other side:
This is the only way that I know to see logs erros. Is there another way?.
Thanks.
If you do show int G2/1 counters errors, that will give you a better breakdown of the error types.
Kevin Dorrell
Luxembourg
Hi.
I can see 6 fcs-errors and 163 rcv-err in this command output.
I think it is very probable that it is a hardware error maybe gbic interface or fibber cable but I hdon't understand why port was donw suddenly. Is this a Cisco switch procedure when an errors ocurred in any port?.
I didn't remember say that in the other side of switch there is a media converter that converts fibber to copper. THe fibber is multimode.
So you have a total of 163 errors, of which 6 are CRCs. Did it not give any indication what the other 157 are?
Kevin Dorrell
Luxembourg
No. I can see any more. If you can say me how I will try it.
you can check the same using show logs from your console or telent session.
regds
I can see nothing about this interface or something relevant with this command
Thanks.
I am having the same problem with one of our switches. What would be a possible problem if a majority of the input errors were CRC errors?
