Webcast-Catalyst9k
Help to identify MIB from a received trap
My default trap receiver has captured the follow trap. I need to know what MIB it's in so that I can write a script to react to this trap. Please help
xxx.xxx.xxx.xxx system.sysUpTime.0 32:15:49:33.44 .iso.org.dod.internet.snmpV2.snmpModules.snmpMIB.snmpMIBObjects.snmpTrap.snmpTrapOID.0 enterprises.cisco.0.1 enterprises.cisco.local.9.3.1.1.33.1 5 tcp.tcpConnTable.tcpConnEntry.tcpConnState.xxx.xxx.xxx.xxx.7001.XXX.XXX.XXX.XXX.1031 0 enterprises.cisco.local.6.1.1.5.xxx.xxx.xxx.xxx.7001.XXX.XXX.XXX.XXX.1031 62154 enterprises.cisco.local.6.1.1.1.xxx.xxx.xxx.xxx.7001.XXX.XXX.XXX.XXX.1031 12727 enterprises.cisco.local.6.1.1.2.xxx.xxx.xxx.xxx.7001.XXX.XXX.XXX.XXX.1031 5514 enterprises.cisco.local.9.2.1.18.33 "" .iso.org.dod.internet.snmpV2.snmpModules.snmpCommunityMIB.snmpCommunityMIBObjects.snmpTrapAddress.0 xxx.xxx.xxx.xxx .iso.org.dod.internet.snmpV2.snmpModules.snmpCommunityMIB.snmpCommunityMIBObjects.snmpTrapCommunity.0 "ABBCN" .iso.org.dod.internet.snmpV2.snmpModules.snmpMIB.snmpMIBObjects.snmpTrap.snmpTrapEnterprise.0 enterprises.cisco
Please note that I have replace IP addresses with xxx or XXX.
Just to let you know that my trap receiver get this trap when someone has exited out of a VTY or TTY. In this example, it's a TTY33
Please Help as this is my final hurdle to work out an effective accounting for dialout users.
Much thanks
Justin Vo
Network Admin
justin.vo@au.abb.com
1 ACCEPTED SOLUTION
Blue
Re: Help to identify MIB from a received trap
You can use either of these tools to translate/search your traps and then load the corresponding MIB(s):
http://www.cisco.com/pcgi-bin/Support/Mibbrowser/unity.pl
http://jaguar.ir.miami.edu/~marcus/snmptrans.html
Blue
You're the Champ !!!
I got the MIB. Weird but definitely the right one.
enterprises.cisco.cisco#.tcpConnectionClose
Thank you for quick response.
Justin Vo
337
