Community Member
Help;Urgent Problem!
Hi All!
yesterday;i've configured a switch with 4 port uplink(EtherChanel)in the side access switch,the channel mode is desirable but by mistake the persom who configured in side core mode chanel is on;then when accees switch startup we have received duplicate ip address.loop,error,and all the access switch down.what is the problem here?what is happen;when we turnOff this switch every thing is fine
the config was like this in the access side:
interface GigabitEthernet0/25
switchport trunk encapsulation isl
switchport mode trunk
channel-group 5 mode desirable
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Port-channel5
switchport mode trunk.
10xs for ur help
Community Member
Re: Help;Urgent Problem!
Change your core switch config (channel group 5) to reflect the access layer. ie Change the core to desirable. That will enable you to get the access layer operational so that you can update.
I have had trouble in the past configuring layer 2 etherchannels in desirable mode.'On' at both ends has always worked however.
Hope that helps. Good luck
Community Member
Hi Freind!
so u advise me to change the mode on the 2 side to ON.ON.LIKE THIS It will work.
10xs
Ali
Ali yes it will work if ur having ON ON on both ends.
Mahmood
Community Member
hi mahmoud!
but all advise me to be desirable mode(prefered methode)
10xs
Ali
hi ali,
that is what i am trying to show you in that table 23-4 of the link: :http://www.cisco.com/univercd/cc/td/doc/cisintwk/itg_v1/tr1923.htm#xtocid44
just read it you will have clear idea of different mode
rate this post if it helps
regards
Devang
Community Member
Exactly, if access layer is set to:
channel-group 1 mode on
Ensure that the core layer interfaces are the same.
channel-group 11 mode on
Whether this is 'desirable' or 'on' shouldn't matter. Once the access layer is up and manageable you can change to the mode that you prefer.
Tell me how it goes.
Community Member
Hi Friend!
in the core the chanel-group 11;and on the access switch the channel-group is 1.how come this?
Ali
Community Member
Channel group number is significant only to the local switch. The numbers can be different at either end. I copied our config which mirrors the interface number that their plugged into. Port 11 & 12 on dist, 1 & 2 access, giving po1 & po11.
Community Member
Hi Friend!
10xs for ur clear!
Ali
117
