Community Member
Help with 3640 subinterface
I am running 12.0(7)XK1 on a Cisco 3640 and can not set up a subinterface on the fastethernet port on a NM1FE2W card.
After typing
config t
int fa 0/0.2
encapsulation is not an option for a command.
Do I need to upgrade from the early release version?
Re: Help with 3640 subinterface
Are you running an IP-image?
The subinterfaces on FE ports are used for inter-vlan routing. (802.1q)
This feature is only supported in IP-plus images.
Community Member
Unfortunately, we are running an IP-image.
Looks like I will have to go with an upgraded 12.0 image.
Not enough memory to upgrade to 12.1.
Thanks a lot.
812
