Help with 801 router
Hi.. I wasnt sure which was the best forum to put this in but i will ask here..
I have spent many hrs now on this now and i have 2 issues i dont know how to fix...
One is ...... How do i edit the config file as i need ot add stuff in the dialer section. ?? Please laymans way. As i dont understand where and how to achive this.
Two .... Second issue i have i can get the moden to connect on isd and i cant ping it on the network and access it via the http://198.... so on.. But i cannot browse the net or use anything at all.. At one stage i was able to use msn and ping ip addresses from my computer and thats all.....
I ahve gave it its own ip and my computer another ip ann under the same mask and agteway.. eg..
router 198.162.0.1
mask 255.255.255.0
gateway 198.168.0.1
then the computer with a 198.162.0.2
and the rest as above.
Like i said it works and dials but i cant do anything else.
The setup is a os winxp pro the router connected to pc and the router to another isdn modem into the sbus ...
So any help would be great. i have no idea what to do anymore......
Thank you in advance..
Slav
Silver
Re: Help with 801 router
You can find a quiet a lot of useful configuration documents of 800 series router here.
http://www.cisco.com/cgi-bin/Support/browse/psp_view.pl?p=Hardware:800&s=Software_Configuration
Thanks i will have a read...
It will be hard to pinpoint the problems you are having with the description you gave. However, getting access to the routers config should not be a problem. Having not worked on an 800 router before i am using knowledge from a 1700 router.
Run a program called Hyperterm and connect to it using TCP/IP and specifcy the IP of the router. Once in you need to get the config mode by using the command - enable
In regard to browsing the internet problem, check the MTU (Maximum Transmission Unit) size the router is trying to squeeze over the internet connection. I have found this with ADSL connections, the default size was over 1500 and i had to reduct it to 1452 to get a good speed/connection over the DSL
And browse the cisco website ! theres a wealth of knowledge here !
78
