Help with a WAN routing problem...
Below is a captured TELNET session. From the main network "PHC"-10.1.1.0 I can ping workstations on "DME" 192.168.132.0. From 192.168.132.0 I can ping as far as the E0 (10.1.1.37) but no IPs beyond that. The first sh run is for PHC the second is DME. Any help is greatly appreciated.
Dennis
sh run
Building configuration...
Current configuration : 946 bytes
version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname phcdme
enable secret xxxxxxx
enable password
memory-size iomem 25
ip subnet-zero
no ip domain-lookup
--More--
interface Serial0
description ckt flzc83709mb to dme
bandwidth 256
ip address 192.168.100.1 255.255.255.0
no keepalive
no fair-queue
service-module t1 timeslots 1-4
interface FastEthernet0
ip address 10.1.1.37 255.255.255.0
speed 10
half-duplex
router rip
redistribute connected
network 10.0.0.0
network 192.168.100.0
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0
ip route 192.168.132.0 255.255.255.0 192.168.100.2
no ip http server
--More--
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
banner motd ^CAccess to this router is restricted^C
line con 0
password
login
line aux 0
line vty 0 4
password
login
end
phcdme#ping 192.168.132.2
Sending 5, 100-byte ICMP Echos to 192.168.132.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/14/16 ms
phcdme#telnet 192.168.132.41
Trying 192.168.132.41 ... Open
User Access Verification
Password:
dmephc>en
Password:
dmephc#sh run
Current configuration:
version 12.1
hostname dmephc
enable password
ip subnet-zero
no ip domain-lookup
--More--
interface Serial0
description ckt flzc83709mb to phc
bandwidth 256
ip address 192.168.100.2 255.255.255.0
no keepalive
no fair-queue
ip address 192.168.132.41 255.255.255.0
speed 10
half-duplex
router rip
network 10.0.0.0
ip classless
ip route 10.0.0.0 255.255.255.0 192.168.100.1
ip route 10.1.1.0 255.255.255.0 192.168.100.1
--More--
no ip http server
line con 0
transport input none
line aux 0
line vty 0 4
password
login
no scheduler allocate
end
dmephc#ping 10.1.1.37
Sending 5, 100-byte ICMP Echos to 10.1.1.37, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/16/20 ms
dmephc#ping 10.1.1.1
Sending 5, 100-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
dmephc#
1 ACCEPTED SOLUTION
Bronze
Re: Help with a WAN routing problem...
You need to check the gateway address and mask of the pc 10.1.1.1. Can you ping it from PHC using extended ping and the IP of the serial link?
Bronze
I have made the gateway of my pc (on the 10.1.1.0) 10.1.1.37. From my workstation I can ping 10.1.1.37 but not 192.168.100.1. That makes no sense. I can ping everything from the router PHC and the router DME (except workstations on 10.1.1.0. The problem is between E0 and S0 on PHC. Line is up, Protocol is up all, Ints are up and running.
Dennis
I have now made the gateway on my workstation (10.1.1.51) 10.1.1.37 and 192.168.100.1 (which I shouldn't have to do) and it works. I can ping from my workstation to PHC, over to DME and IP 192.168.132.2 on the remote network.
I do the same on a server on the network, add to it's gateways: 10.1.1.37 and 192.168.100.1 and I cannot ping 192.168.100.1 from this server. What the heck is going on?
Dennis
Hey rjackson,
Thanks for the help today. One thing I don't understand is; why would I have make the S0 a gateway? Should I not just have to make the E0 a gateway? Why is it now working because I've made both the E0 and S0 a gateway?
Dennis
First of all regarding your configuration, it needs some clean up. You dont need those static routes , if you are running RIP already. For ex, on PHC, the route statement (ip route 192.168.132.0 255.255.255.0 192.168.100.2) is not needed. The network 192.168.132.0 is the lan interface address of DME and this route will be advertised through RIP. Similarly you dont need the static route about 10.1.1.0 network on DME.
You also do not need the redistribute connected command configured under RIP on either routers.
On DME you also dont need a network 10.0.0.0 command under RIP, because there is no interface on that router falling under that network.
A sample configuration on either routers should look like
PHC
router rip
network 10.0.0.0
ip route 0.0.0.0 0.0.0.0 fastethernet0 (this is needed if you have a internet gateway)
DME
router rip
Also the gateways on the PCs on the lan of PHC router should be pointed to 10.1.1.37. You dont need to point them to s0. and the gateways on the PCs on the lan of DME router, needs to be pointed to 192.168.132.41
Try the above configuration and let us know if it works.
Thanks for the help.
From the PHC router I can ping 192.168.132.2
From the DME router I can ping 10.1.1.37 (EO on PHC) but not any IPs on the 10.1.1.0 network. Any ideas?
Dennis
The only way I get a successful ping from DME (192.168.132.41) pinging 10.1.1.51 (my pc on the 10.1.1.0) is to add 192.168.100.1 as the default gateway. Why in the world is that? Should not 10.1.1.37 be a gateway?
Dennis
How does the routing table looks like on your PC ?
"route print" for windows OR "netstat -rn" for unix
Have you tried to ping any other PC on 10.1.1.0 subnet ?
Regards \\ Naman
107
