09-12-2002 02:29 PM - edited 03-02-2019 01:20 AM
I am looking to setup a connection between two 1720 routers via an ISDN BRI connection. This connection will be 24x7x365. I am looking for examples of configurations. Do I want to do DDR?
Thanks!
09-12-2002 05:05 PM
ISDN could get expensive for you if up/connected like that :)
Here is a link with a config:
http://www.cisco.com/warp/public/129/config-bri-map.html
Set the dialer idle-timeout high so link won't go down (saves connection setup time). Also, static routing should be good enough.
Hope it helps
Steve
Log in to Community
