Help with MAC ACLs on switches!!
Hi to all,
I wanted to know what specific type of cisco switch of the 2950 series supports mac acls on individual switch interfaces. I basically want info relating to the IOS version, switch model...
Any help will be greatly appreciated..
Warm regards,
Visham
Re: Help with MAC ACLs on switches!!
Would suggest to go for 12.1(22)EA5 which is again the latest version available for this series switches..
It does supports the require MAC ACL functionaility in the swtich.
Do refer this link for more info on the same.
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a00804cc117.html#wp1075613
regds
VIP Purple
Hello Visham,
I think you need the Enhanced Image (EI) to support named extended MAC access lists, and then at least IOS 12.1(6)EA2c. The following models are EI models:
Catalyst 2950G 48-48 10/100 ports and 2 Gigabit Interface Converter (GBIC)-based Gigabit Ethernet ports
Catalyst 2950G 24-24 10/100 ports and 2 GBIC ports
Catalyst 2950G 24-DC-24 10/100 ports, 2 GBIC ports, DC power
Catalyst 2950G 12-12 10/100 ports and 2 GBIC ports
Catalyst 2950T 24-24 10/100 ports and 2 fixed 10/100/1000BASE-T uplink ports
Catalyst 2950C 24-24 10/100 ports and 2 fixed 100BASE-FX uplink ports
HTH,
GP
176
