Webcast-Catalyst9k
Help with Netconfig
I am trying to use netconfig to update my running-config on a 2620 router. I would like to call the file from tftp server. If I enter the command below into the router, it will copy my changes int the router, but I must hit return once after the file was entered to verify where to write the file.
copy tftp://1.1.1.1/tftpboot/configfile run
When I create a template in netconfig and put in the same command as above, I recieve the following error message:
Update Result: Failed
FAILURE
-CLI OUTPUT-
FAILURE
Any ideas on how the get ciscoworks to call the file from my tftp server ??
Thanks in advance.
Ben
1 REPLY
Silver
Re: Help with Netconfig
Did you check the connectivity to the tftp server? If it is fine, did you double check the filename of the configuration file? If both of these are fine, then I guess, you should be missing some of the NetConfig Requirements given in the document below:
http://www.cisco.com/en/US/products/sw/cscowork/ps2073/products_tech_note09186a00800a6974.shtml#requirements
Or may be, you could use the Config Editor for this purpose.
105
