09-17-2002 06:49 AM - edited 03-02-2019 01:25 AM
My problem is i can not for the life of me get my pc on the 2950 to grab a DHCP addy from the server. 2950 is on port gig0/1 on the 3550 adn is routed to 192.168.1.1 the dhcp server is a win2k box on the 5.0 net with addy 192.168.5.1. included is my configs. ANy help would be much appreciated.
2950
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Cat2950.1
enable secret 5 $1$o7qu$sLdauKCrn/lpyRICYgyit.
enable password xxxxx
ip subnet-zero
ip domain-name xxxxx.com
ip name-server 192.168.5.9
ip dhcp-server 192.168.5.1
interface FastEthernet0/1
no ip address
interface FastEthernet0/2
no ip address
interface FastEthernet0/3
no ip address
interface FastEthernet0/4
no ip address
interface FastEthernet0/5
no ip address
interface FastEthernet0/6
no ip address
interface FastEthernet0/7
no ip address
interface FastEthernet0/8
no ip address
interface FastEthernet0/9
no ip address
interface FastEthernet0/10
no ip address
interface FastEthernet0/11
no ip address
interface FastEthernet0/12
no ip address
interface FastEthernet0/13
no ip address
interface FastEthernet0/14
no ip address
interface FastEthernet0/15
no ip address
interface FastEthernet0/16
no ip address
interface FastEthernet0/17
no ip address
interface FastEthernet0/18
no ip address
interface FastEthernet0/19
no ip address
interface FastEthernet0/20
no ip address
interface FastEthernet0/21
no ip address
interface FastEthernet0/22
no ip address
interface FastEthernet0/23
no ip address
interface FastEthernet0/24
no ip address
interface FastEthernet0/25
no ip address
interface FastEthernet0/26
no ip address
interface FastEthernet0/27
no ip address
interface FastEthernet0/28
no ip address
interface FastEthernet0/29
no ip address
interface FastEthernet0/30
no ip address
interface FastEthernet0/31
no ip address
interface FastEthernet0/32
no ip address
interface FastEthernet0/33
no ip address
interface FastEthernet0/34
no ip address
interface FastEthernet0/35
no ip address
interface FastEthernet0/36
no ip address
interface FastEthernet0/37
no ip address
interface FastEthernet0/38
no ip address
interface FastEthernet0/39
no ip address
interface FastEthernet0/40
no ip address
interface FastEthernet0/41
no ip address
interface FastEthernet0/42
no ip address
interface FastEthernet0/43
no ip address
interface FastEthernet0/44
no ip address
interface FastEthernet0/45
no ip address
interface FastEthernet0/46
no ip address
interface FastEthernet0/47
no ip address
interface FastEthernet0/48
no ip address
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
ip address 192.168.1.22 255.255.255.0
ip helper-address 192.168.5.1
no ip route-cache
ip default-gateway 192.168.1.1
ip http server
line con 0
line vty 0 4
password xxxxxxx
login
line vty 5 15
password xxxxxxx
login
end
3550
version 12.1
no service pad
service password-encryption
hostname Cat3550.1
aaa new-model
aaa authentication password-prompt Password:
aaa authentication username-prompt Username:
enable secret 5 $1$zIuX$yz1VwnKcfNVnIM7EUherP/
enable password 7 050C09062F4B5A0611001B1E
username root password 7 022E054D0E2721284F4B2D181C
ip subnet-zero
ip routing
ip domain-name sssnt.com
ip dhcp relay information option
cluster enable Cisco 0
no switchport
no ip address
interface GigabitEthernet0/3
no ip address
interface GigabitEthernet0/4
no ip address
interface GigabitEthernet0/5
no ip address
interface GigabitEthernet0/6
no ip address
interface GigabitEthernet0/7
no ip address
interface GigabitEthernet0/8
no ip address
interface GigabitEthernet0/9
no ip address
interface GigabitEthernet0/10
no ip address
interface GigabitEthernet0/11
no ip address
interface GigabitEthernet0/12
no ip address
interface Vlan1
ip address 192.168.5.22 255.255.255.0
ip classless
ip default-network 192.168.5.0
ip default-network 0.0.0.0
ip http server
ip access-list extended CMP-NAT-ACL
dynamic Cluster-HSRP deny ip any any
dynamic Cluster-NAT permit ip any any
tftp-server flash
tftp-server flash c3550-i5q3l2-mz.121-11.EA1.bin
tftp-server system 1
line con 0
line vty 0 4
password 7 0118130F4E00070C2959
transport input ssh
line vty 5 15
password 7 030F4E001304204F461C
end
09-18-2002 03:25 AM
I assume you've verified connectivity from the 2950 to the 3550?
Try configuring Spanning Tree PortFast on the end user ports on the 2950.
Otherwise your PC'll be looking for that DHCP server before the switch has opened the port as it transitions thru' Spanning Tree states.
Use either
spanning-tree portfast
on each FastEthernet interface on the 2950 or use
spanning-tree portfast default
in global config mode.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12111ea1/scg/swstpopt.htm
09-18-2002 04:38 AM
i have connectivity no problem. with static ip's the net is fine. I have also done a debug and it looks like the 3550 is forwarding to the correct win2k dhcp server. I have verified my dhcp superscope but it seems that the 3550 is either not receiving a response or is ignoring it.
09-18-2002 05:53 AM
What is the effect of running ipconfig /renew after your host is up and running. In alot of cases the client has issued to dhcp request prior to the switch port being up and ready to forward (due to spanning tree states 'block, listen, learn). If your client can get an address after doing an ipconfig /renew then try setting the interface that the client is connected to 'spanning-tree portfast'. Do not use portfast setting on non-endstation systems like routers, hub or neighbor switches as this could cause stp loops. For end station interface config it should look like
no ip address
Hope this helps.
Paul
