Help with some ACLs for VACL
I need some help with acls for a vacl. Goal - have the 1.1.1.0/24 subnet only communicate with certain IP.
So, they cannot get out to anywhere else and no one except that IP can get in.
Here is what I have so far:
access-list acl1 permit tcp 1.1.1.0 255.255.255.0 host 1.2.3.4
access-list acl1 permit tcp host 1.2.3.4 1.1.1.0 255.255.255.0
access-list acl1 ip 1.1.1.0 255.255.255.0 any log
access-list acl1 ip deny any any log
vlan access-map vacl1 1
match ip address set acl1
action forward
exit
vlan filter vacl1 vlan-list 11
Will this work as I expect it to?
Thanks for any help
  • Other Network Infrastructure Subjects
Re: Help with some ACLs for VACL
Looks okay, theoretically, vacl map would allow packets that the acl permits from host .4 from subnet 1.1.1.x and vise versa. I would be careful with log keyword, this would cause the packet be processed in software which would casue the cpu to spike.
Please rate helpful posts.
I implemented this on my 6509 and it didn't work. I even modified it to look like the following and it didn't work (I could RDP to one of the boxes on that the subnet).
ip access-list extended rapt_acl
deny ip any any
deny tcp any any
deny udp any any
vlan access-map rapt_vacl 10
match ip address set rapt_acl
action forward
vlan filter rapt_vacl vlan-list 90
Any thoughts what I may be missing?
yeah, the ACL does not permit anything at all. what are you trying to forward again?
I was testing the acl in the first post and it should have only allowed port 80 to the server and port 25 out. However, it did not work because I could still RDP to the box. So, I tested with deny any any and I still could rdp tothe box. I was expecting no access in or out with the deny.
Not sure what i am doing wrong or missing.
121
