Help with VLANs...
My network consist o
Cisco Switch
I have a C3524XL setup with all my Fast Erthernet ports setup like the example below.
interface FastEthernet0/8
switchport trunk native vlan 10
switchport mode trunk
switchport voice vlan 14
switchport priority extend cos 0
spanning-tree portfast
The 6509 is forwarding all the VLANs. Now all of a sudden the users in that picticular VLAN will not connect to any other VLAN.. I had to setup the FA Port like the example below for the nework to work. Can Anyone explain why that is?
switchport access vlan 10
Re: Help with VLANs...
An access port should not be setup to trunk. Only uplink ports that connect
to the 6509 should be in trunking mode. If you want more than one VLAN
to be on an access port you will need to make the second VLAN an auxillary
VLAN. If a port is an access port within a VLAN and not trunking, no encapsulation is needed. Be sure that the port that uplinks to your 6509
is in trunking mode; otherwise, multiple VLANs on the switch will not make
it to the 6509.
Thanks thats helps alot
Yes, a 3500 XL access port should be configured with trunk, if you have IP telephones on that port. The configuration that lagasse sent is actually text-book for how to configure a port for an IP telephone.
-A
84
