Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
c.b
HELP
I have just had to re configure our 803 router due to changing ISP's. Ive taken the old routing config, changed the relevant ip's and DNS details and uploaded that config into the router. I am now able to ping the SADSL modem which is set as the next hop, however I cant get any furthur. The domain name servers are unreachable. It seems the modem is the only place I can get to.
I have tested the IP etc work by connecting a pc directly to the modem, bypassing the router. Everything seems fine..
Anyone know what Im doing wrong??
Re: HELP
You may need to post your config, the problem is likely to be in there somewhere. You stated that you set the ADSL-modem as next hop. This is likely to be wrong. Assign the route either to the interface or to the next-hop router's IP adress.
Goodluck
Leo
c.b
Re: HELP
Thanks Leo
Here is the config, the next hop is a router/sadsl modem. Ive been told by my ISP that this modem has been setup as the gateway to their side, unfortunatly Ive no control over the modem so dont know how its actually configured. However they tell me it is correct to have it as the next hop.
the config is:-
version 12.1
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Router
enable secret 5 **
ip subnet-zero
no ip source-route
no ip routing
ip name-server 203.134.**.**
no ip finger
interface Loopback0
no ip address
no ip proxy-arp
interface Loopback1
ip address 172.16.2.99 255.255.255.0
ip nat inside
ip policy route-map nat
interface Ethernet0
mac-address 0002.1762.b6ec
ip address 172.16.1.99 255.255.255.0 secondary
ip address 211.26.**.** 255.255.255.240
no ip redirects
no ip unreachables
ip nat outside
no cdp enable
interface BRI0
no ip address
no ip route-cache
no ip mroute-cache
shutdown
no cdp enable
ip nat inside source list 1 interface Ethernet0 overload
ip nat inside source static tcp 172.16.1.41 80 211.26.**.** 80 extendable
ip nat inside source static tcp 172.16.1.41 25 211.26.**.** 25 extendable
ip nat inside source static tcp 172.16.1.41 53 211.26.**.** 53 extendable
ip nat inside source static udp 172.16.1.41 53 211.26.**.** 53 extendable
ip nat inside source static tcp 172.16.1.202 80 211.26.**.** 80 extendable
ip nat inside source static tcp 172.16.1.202 554 211.26.**.** 554 extendable
ip nat inside source static tcp 172.16.1.202 7070 211.26.**.** 7070 extendable
ip nat inside source static tcp 172.16.1.202 1220 211.26.**.** 1220 extendable
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Loopback1
access-list 1 permit 172.16.0.0 0.0.255.255
access-list 2 permit 202.72.**.**
access-list 2 permit 172.16.1.18
access-list 2 permit 172.16.1.14
access-list 2 permit 172.16.1.7
access-list 2 permit 211.26.3**.**
no cdp run
route-map nat permit 10
set ip next-hop 211.26.**.**
snmp-server community public RO
snmp-server community Info RO
snmp-server contact connie@core3d.com
snmp-server chassis-id JAD05300J9U
line con 0
password 7 **
login
transport input none
stopbits 1
line vty 0 4
access-class 2 in
exec-timeout 0 0
password 7 **
login
end
Re: HELP
I think you should apply the route-map "nat" on the inbound interface, ethernet 0 rather than at the loopback interface. Try reconfiguring the policy routing into the ethernet interface.
Re: HELP
c.b. - What is the make/model of your ADSL "modem/router"? It will have a network interface, which in turn will need to fit your IP address scheme. Did your ISP setup your LAN interface on the ADSL router with your 172.x.x.x? I just wonder if they setup your NAT correctly.
Bruce Davis, CCNA since 2003
102
