HHHHHHHEPL ME -Async Device Connectivity Problem
Head Office and Branch offices are connected over 128 Kbps leased line using Cisco 3620 routers. I want to connect a dump terminal on the Branch Office router through the Async Port using RS232-SS cable.
Async port of Head office router would to connected to Unix Server through RS232-SS able.The Leased line Internetwork between the routers is running on IP/IPX
I tried to create ASYNC DATA Tunnel but it did not work,
The following setup I used to test the connectivity in the Lab test:
Two PCs are connected through the serial cables on either end of Internetwork ( i.e. To Router ASYNC port)-Created Async Data Tunnel describe in the document and using LL3 software-Tried to established the connectivity but did not succeed.
Configuration of Head Office router:
version 12.1
no service single-slot-reload-enable
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname headoffice
logging rate-limit console 10 except errors
enable secret 5 $1$BaIK$6SMHDs5WCGRUqPCKeU9jK.
enable password 7 02151D481F14002F1D
username remoteoffice password 7 05181F1C355E410759
ip subnet-zero
no ip finger
ipx routing 0006.28d6.6241
isdn switch-type basic-net3
interface FastEthernet0/0
ip address 200.1.1.150 255.255.255.0
speed auto
full-duplex
ipx network 1
no mop enabled
interface Serial0/0
ip unnumbered FastEthernet0/0
ipx network 11
interface Serial0/2
physical-layer async
no ip address
interface BRI1/0
no ip address
encapsulation ppp
dialer rotary-group 1
no cdp enable
interface BRI1/1
no ip address
encapsulation ppp
dialer rotary-group 2
no cdp enable
interface BRI1/2
no ip address
shutdown
interface BRI1/3
no ip address
shutdown
interface Dialer1
encapsulation ppp
dialer in-band
dialer idle-timeout 300
dialer map ip 200.2.1.150 name remoteoffice broadcast
dialer map ipx 12.0006.5365.c6e1 name remoteoffice brodcast
dialer hold-queue 10
dialer-group 1
ipx network 12
no ipx route-cache
ipx watchdog-spoof
ipx spx-spoof
no cdp enable
ppp authentication chap
router rip
version 2
network 200.1.1.0
no auto-summary
ip classless
no ip http server
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
line con 0
transport input none
line 3
no exec
no exec-banner
exec-timeout 0 0
no vacant-message
modem DTR-active
transport input telnet
stopbits 1
line 4
line aux 0
line vty 0 4
password 7 120A1C040619030A
login
end
Configuration of Remoteoffice router:
version 12.1
hostname remoteoffice
enable secret 5 $1$95mV$po.jiIBUlEgcHPCWtFemC/
enable password PASSWORD
username headoffice password 0 PASSWORD
ip subnet-zero
no ip finger
ip host CALLED-LINE 4003 200.5.1.150
ipx routing 0006.5365.c6e1
ip address 200.2.1.150 255.255.255.0
speed auto
full-duplex
ipx network 10
no mop enabled
interface Serial0/0
backup delay 10 10
backup interface Dialer1
ipx network 11
interface Serial0/1
no ip address
shutdown
clockrate 2000000
interface Serial0/2
no ip address
interface Serial0/3
no ip address
shutdown
clockrate 125000
interface BRI1/0
no ip address
encapsulation ppp
no cdp enable
interface BRI1/1
no ip address
shutdown
interface BRI1/2
no ip address
shutdown
interface BRI1/3
no ip address
shutdown
interface Dialer1
encapsulation ppp
dialer in-band
dialer map ip 200.1.1.150 name headoffice broadcast 065522345
dialer map ipx 12.0006.28d6.6241 name headoffice broadcast 065522345
ipx network 12
no ipx route-cache
ipx watchdog-spoof
ipx spx-spoof
no cdp enable
router rip
version 2
network 200.2.1.0
ip classless
no ip http server
line con 0
line 3
no motd-banner
no exec-banner
exec-timeout 0 0
no flush-at-activation
no activation-character
no vacant-message
autocommand telnet CALLED-LINE /stream
special-character-bits 8
escape-character NONE
stopbits 1
line aux 0
line vty 0 4
password PASSWORD
login
end
Is there any other way to configure Async port on each of the routers for dump terminal at Branch office to Connect to Unix Server at Head office?
IMPORTANT NOTE: EXISTING CONFIGURATION HAS MULTIPLEXER AND LAN2LAN CARD FOR NETWORK AND ASYNC DEVICE CONNECTIVITY.
Thanks in advance.
1 REPLY
Re: HHHHHHHEPL ME -Async Device Connectivity Problem
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
107
