hi,all, i have a problem with cat3550
i use the "delete flash" and "reload" in switch, and went into the romon mode(i guest), when i try to do "dir flash" or "dir null" or "dir xmodem" it said permission deny. I am using reverse telnet to the console because it is a lab enviroment for my ccie preparation.
I used "flash_init " and "format" command to format and init tht flash system, it allowed me to do so,but after that it still said that permission deny if i do "dir flash" and i can't download the backup from the tftp server.
any input will be appreciated
thanks a lot
1 REPLY
Bronze
Re: hi,all, i have a problem with cat3550
The missing colon character in the command could probably create problems. Try ' dir flash: ' instead of 'dir flash' . This doc might help you :
http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
92
