Hi,What is crash info ?
6509 have a log list below:
00:00:33: %C6K_PLATFORM-5-LESS_SPACE: May not have enough space to save the crash info. on flash of Router on module: 1
My questions:
1.What is crash info ?
2.Why 6509 have start crash info ?
3.Why 6509 reload after appear crash info ?
Re: Hi,What is crash info ?
crashinfo is a file that stores information about a previous crash of the software subsystem in the catalyst (any cisco device in general). This file is stored in flash memory in a catalyst. This file will have information like stack traces, which basically holds the information (will have to decoded to reveal this info), why the switch software crashed. This information is generally useful to a Cisco TAC engineer. You are probably running out of space on your flash chip. Check to see if you have any unwanted files (or multiple files stored in flash). If there are files that are deleted and not yet squeezed, squeeze them and try making up more space.
VIP Purple
obviously the Flash device does not have enough space and crash information might not be saved.
Check for unnecessary files from the Flash device and enter the squeeze command for the device.
I assume your router has crashed ? Can you post the result of the show stacks command ?
Georg
Hi,Thanks.
I am think the 6509 hardware have some problems cause software crashed ,And The 6509 native ios version is
c6sup22-jsv-mz.121-13.E10.bin.
------------------ show stacks ------------------
Minimum process stacks:
Free/Size Name
5736/6000 OIR IOS Process
2712/3000 Standby Time
5596/6000 IPC Zone Manager
3536/6000 IPC delayed init
5724/6000 ICC Retry Q
3868/6000 IPC delayed funcs
5632/6000 QM OIR Proc
5636/6000 Draco FIB process
4844/6000 eobc_init_process
3852/6000 ICC Slave Comp. Up
5620/6000 PM MP Process
5428/6000 C6K ENV RP init
3688/6000 SPAN Subsystem
11260/12000 Router Init
5600/12000 Init
3604/6000 CDP Protocol
3744/6000 Draco DFS Port Registation Proc
772/3000 EARL INFO CAPABILITY process
5316/6000 RADIUS INITCONFIG
3568/6000 LCC Configure
5240/6000 CEF Reloader
8076/9000 DHCP Client
8756/12000 Virtual Exec
Interrupt level stacks:
Level Called Unused/Size Name
1 432783 7892/9000 Inband Interrupt
2 261697 6360/9000 EOBC Interrupt
3 2130 8492/9000 Management Interrupt
4 3646 8640/9000 Console Uart
5 0 9000/9000 Mistral Error Interrupt
7 526474 8600/9000 NMI Interrupt Handler
A show stacks decode using Output Interpreter doesnt reveal any sign of a crash. Give a show flash or show bootflash and see if you have any unwanted files (that were deleted but not squeezed). If yes remove them, to make up more space in flash.
Hi,I have a question ,if flash or bootflash no more space ,
Then 6509 would reboot itself frequency ?
Gold
No, running out of bootflash shouldn't make the router crash. But it will keep the router from writing a crashinfo file, which would help TAC determine the cause of the crash in the first place.
Russ.W
Hi,Thanks.But I cann't open tac with cisco,Can you help me ?
thanks!
Gold
Can you post a show stack?
Thanks!
Russ.W
190
