High CPU Usage / Dropped Packets - Switch Blade WS-CBS3120X-S
Hi all,
I have a couple of Switches Blade 3120, working as active-standby model (HSRP) on a new site deployment. There are other 20 sites more or less, working on the same model, without issues. But in this one, we are seeing a high cpu usage. The traffic going through the platform is 600Mbps (on peaks), and in this case we have 40% of CPU usage. Traffic should be close to 3 Gbps. When we tried to send the whole traffic through the platform, active switch began to drop packets on the majority of interfaces.
When we analyze the CPU usage, there is a special process called "HL3U bkgrd proce" always have the most CPU use, but we do not know what concerns. We do not know if it is caused because there are PBRs configured. It should not matter. How I mentioned, there are other sites working fine and have had always the same PBR number.
Could you guys help us?. Any idea what is causing the high usage?. Is there a special debug we could to perform to diagnose the issue?. Also, we have seen a high interrupt CPU usage (9% in this case).
Find attached the whole diagnosis outputs.
Thanks for your assistance guys.
Cheers,
Juan Pablo
bog-sib-INT-rtr-1#show processes cpu sorted 5sec
CPU utilization for five seconds: 30%/9%; one minute: 25%; five minutes: 23%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
157   140004809   107071220       1307 14.24% 10.19%  9.01%   0 HL3U bkgrd proce
119     6860957     1519183       4516  0.79%  0.59%  0.53%   0 hpm counter proc
166     2511492      302802       8294  0.15%  0.15%  0.15%   0 HQM Stack Proces
199     4182906    15255882        274  0.15%  0.21%  0.20%   0 IP Input
357      237531      782101        303  0.15%  0.03%  0.00%   0 IP SNMP
186         101         148        682  0.15%  0.09%  0.02%   1 Virtual Exec
242       63071     2330717         27  0.15%  0.02%  0.00%   0 CEF: IPv4 proces
  12      163754      620353        263  0.15%  0.01%  0.00%   0 ARP Input
   9           0           2          0  0.00%  0.00%  0.00%   0 License Client N
   8          41        1827         22  0.00%  0.00%  0.00%   0 WATCH_AFS
  11          50           4      12500  0.00%  0.00%  0.00%   0 Image License br
   7           0           2          0  0.00%  0.00%  0.00%   0 Timers
bog-sib-INT-rtr-1#sh ip cef summary
IPv4 CEF is enabled for distributed and running
VRF Default
119 prefixes (119/0 fwd/non-fwd)
Table id 0x0
Database epoch:        2 (119 entries at this epoch)
Hall of Fame Super Gold
Haven't played with this blade for a long time ...
1.  What IOS version do you have?
2.  Can you post the output to the command "sh interface "?
Hi Leolaohoo,
I had not played with this one too !!!!...
1). IOS version (It was recently updated)
bog-sib-INT-rtr-1#sh ver
Cisco IOS Software, CBS31X0 Software (CBS31X0-UNIVERSALK9-M), Version 12.2(58)SE1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 04:08 by prod_rel_team
ROM: Bootstrap program is CBS31X0 boot loader
BOOTLDR: CBS31X0 Boot Loader (CBS31X0-HBOOT-M) Version 12.2(0.0.951)SE3, CISCO DEVELOPMENT TEST VERSION
bog-sib-INT-rtr-1 uptime is 2 weeks, 3 days, 17 hours, 14 minutes
System restarted at 00:59:27 UTC Sat Jun 9 2012
System image file is "flash:cbs31x0-universalk9-mz.122-58.SE1.bin"
2). What interface do you want to see?, do you want to see all interfaces? . This switch has 16 interfaces that connect servers, and other going to our client. Below, the state of the two kind of interfaces:
Interface to Client (Bearer)
TenGigabitEthernet1/0/1 is up, line protocol is up (connected)
  Hardware is Ten Gigabit Ethernet, address is 001f.275d.d81b (bia 001f.275d.d81b)
  Description: BearerNContent_Aggregrate
  MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 10/255, rxload 14/255
  Keepalive not set
  Full-duplex, 10Gb/s, link type is auto, media type is 10GBase-LR
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 2w3d, output hang never
  Last clearing of "show interface" counters 07:07:56
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 562469000 bits/sec, 83641 packets/sec
  5 minute output rate 430500000 bits/sec, 73141 packets/sec
     2020563158 packets input, 1739897855828 bytes, 0 no buffer
     Received 13257 broadcasts (13257 multicasts)
     0 watchdog, 13257 multicast, 0 pause input
     1745065310 packets output, 1347244137726 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Interface to Server
GigabitEthernet1/0/8 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 001f.275d.d808 (bia 001f.275d.d808)
  Description: bog-15
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 15/255, rxload 12/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseX
  Last input never, output 00:00:17, output hang never
  Last clearing of "show interface" counters 07:09:12
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 19418
  5 minute input rate 47705000 bits/sec, 7155 packets/sec
  5 minute output rate 58897000 bits/sec, 8011 packets/sec
     178178750 packets input, 153802177226 bytes, 0 no buffer
     Received 4091 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     212233312 packets output, 206621942776 bytes, 0 underruns
Thanks for your help. I am losing my hair with this issue.
Cheers,
Juan P.
Hmmmm ...
What's connected to GigabitEthernet1/0/8?  It sounds like the interface is pushing as much as it can but the remote end is can't process the inbound data and the switchport is dropping the packets.
893
