Webcast-Catalyst9k
high cpu usage of r6509 for ip input
I met the problem that high cpu usage of r6509 for ip input . The 6509 has two ws-x6k-sup1a-2Ge for backup ,the main card named R6509 and the other named r6509.Now something is puzzling us: the two card ofen automaticlly standby and active .Cpu usage of the r6509 keeps high even to alerting,but the main R6509 not.Sometimes all the main points -R12000 syncronizlly down with r6509.thanks for your help !
1 REPLY
Re: high cpu usage of r6509 for ip input
There are a lot of things to go over for high cpu utilization. Have your configs looked over and check to make sure debugging is turned off.
191
