High CPU utilization on Catalyst 3500 XL switches.
Hi we have a customer with several Cat. 3500 XL switches. 12, 24 and 48 ports. They are all running software version 12.0(5.4)WC(1).
All of the switches is showing CPU util of 98-99% when using the command "show proc cpu". I know that this has nothing to do with the switching performance but normally this value is between 40 to 50 %.
The process "router autoconf" is run about 40 % which I have not seen before.
Has anybody else seen this ????
Thanks in advance
Tom-Erik Hestholm
1 REPLY
Re: High CPU utilization on Catalyst 3500 XL switches.
We had this with a customer, it is a bug.
This seems to be bug ID CSCdv21552
When a switch boots up with a vlan without an IP address and in
shutdown state, and another vlan has an IP address and is up, cpu
utilisation will go up to 99% when running version 12.0(5.4)WC1
This problem dosnt happen in releases 12.0(5.3)WC1 or older.
388
