Webcast-Catalyst9k
HIPPA compliance and PIX recommendation
I am proposing a network solution to a medical facility comprising 10 sites which must meet HIPPA compliance. In this proposal we are going to colocate all of their servers at our headquarters and use Windows 2000 terminal services for connection between the remote sites and our headquarters. We will have a 3600 router at the colocation site and will routing all traffic from these medical facilities into a PIX firewall which will also act as the VPN tunnel endpoint for these connections. There will be approximately 25 users at each site, so 250 concurrent users over the 10 VPN site connections. What PIX model do you recommend? Additionally, each site wil feature a Cisco 806 router as the other end of the VPN tunnel. Does this design seem feasible. Can you suggest any improvements, which will still be cost effective and remain HIPPA compliant?
Bronze
Re: HIPPA compliance and PIX recommendation
I think your design looks good. I would probably place a PIX 515 there.
Thank you for your comments.
192
