Hot standby between Cisco and 3com
I had a 3com corebuilder 9000, to avoid the single-point failure I want to use a Cisco 3550-12T to build a hot standby solution. As the following,
server
CB9000 3550-12T
PC PC
Can this work good?
Daniel
1 REPLY
Re: Hot standby between Cisco and 3com
I think you need to configure a trunk between the CB and Cisco switch. ( dot1q would be fine. That way you dont need redudant connection from the PC to either switches. They can be connected to any of the switches. The link between the CB and the 3550 should help in failover. \
Hope that helps!
101
