Webcast-Catalyst9k
How can i create a pass through interface between 2 cisco switches that are connected via fiber.
How can i create a pass through interface between 2 cisco switches that are connected via fibre. (I have a single connection that i would like to plug into one of the ports on 1 of the cisco switches and be able to recieve it on another cisco switch only.)
1 REPLY
HiWhat kind of connection are
What kind of connection are you referring to? You can create a new vlan and assign the corresponding port on switch 1 and also in switch 2 and allow the vlan in the trunk interface (i guess your fiber is a trunk uplink).
regards
Najeeb
70
