Community Member
How can i solve the "excessive input rate of traffic problem on Cat4000 ?
Our c4k has some error : Rcv-err, runts and FCS on the same port.
Rcv-err counter is same runts + FCS.
I don't know where runts and FCS error cause to Rcv-err , or Rcv-err cause to runts and FCS.
And I wonder how can i do against excessive input rate of traffic (Rcv-err).
Is there any method to control input buffer on Cat 4000 ?
Re: How can i solve the "excessive input rate of traffic problem
What line card are you having problems with? Is it a fastethernet or gigabit?
What software version are you running? We also had few bugs which could cause FCS errors to increment.
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCdr37645
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCdt15053
Community Member
Our line card is WS-X4232-L3 (JAB054006J4) and use only 10/100 ports.
and CatOs version 5.5(13a).
Community Member
rcv-err is the sum of all receive errors. some of our documenation may show rcv-err as receive buffer failure which is not true for cat4k. So yes, your real problem is FCS/Runts. which typically caused by bad cabling/speed duplex mismatch/faulty nic/patch panel.
There is no way to control input buffer regardless. In this case it is not the problem anyway.
188
