How can I take load balancing of static routing on Cisco 2501?
My name is Jinho-lee
We have some problem to support load balancing of static routing on cisco 2501
I would like to solve this problem ..
I had searched on cisco manual but could not search that ..
How can I solve this problem to support load balancing of static routing on cisco 2501 ?
Thanks to listen my question carefully ....
Re: How can I take load balancing of static routing on Cisco 250
to have loadbalancing, you need at least 2 routes for the same destination.
If you want to do this with static routes, you need 2 static routers for every destination.
Once you have configured the 2 routes, do a 'sh ip route x.x.x.x' and make sure you see 2 possible next-hop. If only one, you have a next-hop unreachable.
If you see 2, and still believe you have a loadbalancing issue, please explain to us what kind of issue.
Don't forget that depending on the switching mode, you will have different type of loadbalancing
- per packet if process switching
- per destination if fast swtiching
- configurable if cef switching
Thanks you to answer ....
But..
I have some question one more ..
If the same destion is not..when the different destion is , How can I solve it ..?
Remainly, To load balancing , have we need to two routers??
Bronze
What GDFOUR tried to tell you is having two static ROUTES not static ROUTERS. And if not to the same dest, then it's very simple to load balance, just divert some networks through one link and remaining through others.
Regards...
--Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
let's take an exmaple.
We have 1 router called R1 connected to R2 and R3.
Both R2 and R2 knows how to reach network 10.0.0.0/8
To have loadbalancing you would configure sth like this on R1 :
ip route 10.0.0.0 255.0.0.0 R2
ip route 10.0.0.0 255.0.0.0 R3
Then issue a 'sh ip route 10.0.0.0' and make sure you see both R2 and R3 as next-hop
136
