For the 1600 series routers, if the command "physical-layer async" command is supported,
it can run on async. The same command also applies for the the NM-8A/S and NM-4A/S network
modules and WIC-2A/S cards. If you have other modules, PAs, and so on, you might want to
check if the command is available.
HTH.
