Webcast-Catalyst9k
How can I use command to verify a serial interface is syn or asyn?
Hi all,
Does any body know how to verify a serial interface is syn or asyn? (I can not see it use "sh int" and "sh controller"). and Can I use an asyn port to connnect to a lease line? or Does it depend on the DTU? Thank You!
Best Regards
Teru Lei
1 REPLY
Bronze
Re: How can I use command to verify a serial interface is syn or
For the 1600 series routers, if the command "physical-layer async" command is supported,
it can run on async. The same command also applies for the the NM-8A/S and NM-4A/S network
modules and WIC-2A/S cards. If you have other modules, PAs, and so on, you might want to
check if the command is available.
HTH.
83
