How do I correct the problem of two routers with the same OSPF Router IDs?
Anonymous
N/A
Re: How do I correct the problem of two routers with the same OS
router ospf xxx
router-id ip-address
The new router id is used only after a reload.
The answer above is correct, though you don't really need to reload, you can just simply clear the OSPF process with the following command:
clear ip ospf 1 process
Hall of Fame Super Gold
10 years old topic, unlikely the OP is still waiting for an answer.
Purple
442
