10-31-2007 09:02 AM - edited 03-03-2019 05:35 AM
I have 3750s running IOS 12.2(40)SE as a L3 switch using EIGRP. I have two vlans with IP addresses assigned and everything is working great, except I notice that most of the traffic is processor switched. In the 3750 how do you get traffic to not be process switched?
VoIP-MDF-SW3750-54-15#sh int stats
Interface Vlan1 is disabled
Vlan54
Switching path Pkts In Chars In Pkts Out Chars Out
Processor 632366 105372316 1038956 109093254
Route cache 460 28952 0 0
Total 632826 105401268 1038956 109093254
Vlan910
Processor 445714 66703846 324654 25300982
Route cache 0 0 0 0
Total 445714 66703846 324654 25300982
FastEthernet1/0/1
Processor 0 0 1568606 124838684
Route cache 0 0 0 0
Total 0 0 1568606 124838684
FastEthernet1/0/2
Processor 0 0 1568586 124868792
Route cache 0 0 0 0
Total 0 0 1568586 124868792
FastEthernet1/0/3
Processor 0 0 885767 75733684
Route cache 0 0 0 0
Total 0 0 885767 75733684
VoIP-MDF-SW3750-54-15#sh ip int vlan 54
Vlan54 is up, line protocol is up
Internet address is 164.xx.xx.xx/25
Broadcast address is 255.255.255.255
Address determined by non-volatile memory
MTU is 1500 bytes
Helper address is 164.xx.xx.xx
Directed broadcast forwarding is disabled
Multicast reserved groups joined: 224.0.0.1 224.0.0.2 224.0.0.22 224.0.0.13
224.0.0.10
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Local Proxy ARP is disabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is enabled
IP CEF switching is enabled
IP CEF switching turbo vector
IP Null turbo vector
IP multicast fast switching is enabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast, CEF
10-31-2007 09:09 AM
However, I recommend against it. It will cause high CPU usage.
