How do I load balance BGP?
jpoulos
I am currently using Route maps and prepend statements, but is there a way that I can truly load balance with BGP? How do the ISP's do it?
Thanks in advance,
Jpoulos
CCNP, MCSE
james.feger
BGP is not designed to load balance traffic. You can load balance between multiple circuits between the same two router's, but not to different routers.
Example:
Router A has three DS3's to Router B
You setup three static routes from Router A to Router B's loopback address, and vice versa. You then build the BGP session to the loopbacks. This will balance the traffic.
ruwhite
Level 7
Level 7
Look for ibgp multipath for bgp load balancing. It doesn't sound like this is what you are trying to do, though....
Russ
ywdi
You can set LocalPreference value of the routing update to archive outgoing traffic load balance. Also you can set metric to the traffic comming to the AS.
ramesh.krishnan
hi,
as such bgp doesnt do any load balancing. what you can do is add 2 static routes thru the different interfaces thru wehich u connect to your upstream provider. then you can instruct the provider also to do the smae at his end. your load will be balanced then.
thanks,
ramesh
