How do I set up frame-relay keepalives on a main interface basis on a router?
I have a headend router with 6 serial interfaces. I want to turn on frame-relay keepalives configuration on just ONE of the interfaces. Is this possible and if so how do I do it?
1 REPLY
Anonymous
N/A
Re: How do I set up frame-relay keepalives on a main interface b
You need to use the "keepalive"
command. Note that this controls
the exchange of LMI updates.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fwan_c/wcffrely.htm#xtocid16
Keepalives are enabled by default.
155
