How do I tell how big flash memory is?
Greetings,
I am filtering through a box of memory for a 2651 router. If the system boots in ROMMON mode, how can I tell how big that particular stick of flash memory is?
meminfo will only show main memory and dir flash: will only show size of current contents.
Re: How do I tell how big flash memory is?
I don't think there is a way to do that, you could assume it is factory default and use the suitable ios to find out if it is expanded. Another option is to just open it and look whats in there.
Thanks for the reply...
I am sifting through a big box of unmarked memory... unfortunately they don't say how big each stick is...
I just thought there might be a rommon command that would tell me.... I guess not.
213
