Community Member
How do I verify the power supply status of a Catylst 4000 with 2 power supplies.
I've just had one of the power supplies replaced as it was faulty, however there was no indication in the log that the power supply had been replaced.
The switch is running the following ios:
IOS (tm) L3 Switch/Router Software (CAT4232-IN-M), Version 12.0(7)W5(15d) RELEASE SOFTWARE
The "show environment" command is not supported.
Full "show version" follows:
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Mon 05-Jun-00 16:39 by integ
Image text-base: 0x60010928, data-base: 0x605C8000
ROM: System Bootstrap, Version 12.0(7)W5(15b) RELEASE SOFTWARE
ANZAK7-B5 uptime is 2 hours, 12 minutes
System restarted by power-on at 08:54:15 NZST Tue Mar 26 2002
Running default software
cisco Cat4232 (R5000) processor with 57344K/8192K bytes of memory.
R5000 processor, Implementation 35, Revision 2.1
Last reset from power-on
1 FastEthernet/IEEE 802.3 interface(s)
4 Gigabit Ethernet/IEEE 802.3z interface(s)
123K bytes of non-volatile configuration memory.
16384K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x2
1 REPLY
Anonymous
N/A
Re: How do I verify the power supply status of a Catylst 4000 wi
show system will provide that info (look under PS1-Status, PS2-Status)
238
