Community Member
How do we know packets using Strict Priority queue for VoIP
We have an VoIP network where an IP phone is connected to c2950 switch. I have configured the IP phone to trust dscp values, L3 Sig = 24 and L3 Voice = 46 (Bearing in mind using Cisco default values of VoIP COS=3, COS=5). The IP phone is not Cisco IP phone. It is working but I would like to check packets are send out from the strict priority queue for DSCP values of 46 (cos=5).
Below is the port interface configuration:
interface FastEthernet0/14
description LAN port for IP phone/PC
switchport access vlan 103
switchport voice vlan 115
no ip address
mls qos trust dscp
spanning-tree portfast
interface FastEthernet0/44
switchport mode trunk
no ip address
mls qos trust dscp
Here is the switchport status of the port
#show interface fa0/14 switchport
Switchport: Enabled
Administrative Mode: dynamic desirable
Operational Mode: static access
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: native
Negotiation of Trunking: On
Access Mode VLAN: 103 (VLAN0103)
Trunking Native Mode VLAN: 1 (default)
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Protected: false
Voice VLAN: 115 (VLAN0115)
Appliance trust: none
Silver
Re: How do we know packets using Strict Priority queue for VoIP
try 'sh mls qos int f0/14 statistics'
Community Member
Well,
I did try to enter this command,
it does not have word 'statistics' in the command field.
Any ideas
97
