how does the 2501 connect a switch?
there is only 2 serial port on the 2501,how does it provide connectivity between a router and a switch?
1 ACCEPTED SOLUTION
Purple
Re: how does the 2501 connect a switch?
AS Vlad mentioned, you need to use the AUI interface. The following link explains this further:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/cis2500/2501/2500ug/inst.htm#26871
Hope that helps - pls rate the post if it does.
Paresh
Is there an AUI interface?
You can use this interface (using an adapter) to connect it to an ethernet interface.
Vlad
Purple
Paresh
149
