Community Member
How is multilink PPP affected by setting interface bandwidth?
I have two T1's bundled via multilink PPP. So bandwidth defaults to 3088.
Due to some routing issues (ie - two multilink hops favored over a direct T1), I've set bandwidth on the multilink interface to 1544.
My question is, will this affect the throughput I am able to get on the interface?
I've been checking periodically and haven't noticed it ever going above 1544, but that's obviously not conclusive evidence...
1 REPLY
Anonymous
N/A
Re: How is multilink PPP affected by setting interface bandwidth
The setting of bandwidth on interface is for use
by routing protocols or doing % bandwidth classification for QOS.
Your clocking rate or access speed actually determines your throughput. so if your access
speed is T1, you get T1 speed on each interface.
110
