Community Member
How many calls per second can an AS5300 handle?
I have an AS5300 and under heavy call volume the signalling between it and my Nortel GSP switch gets messed up. The Nortel switch will show the channels in a "locked out" state. Once the call volume has gone down I can reset the channels in my switch and they will come out of lock out and beging processing calls again. The only way I can keep this from happening is by reducing the amount of traffic being sent to the router from my switch. What is the calls per second limit on this? From what I've been able to find it looks like it is 2 calls per second. Is this correct?
1 REPLY
Anonymous
N/A
Re: How many calls per second can an AS5300 handle?
Yes. 2 cps
204
