I know that theoretically it is possible to install everything on one machine. On the other, there are recommendations that certain parts of the software should not be installed on the same system. E.g. one had better install RTM on a machine different from CW2K. Same is true for VHM as far as i know.
But what about the rest? ACLM must run on the same machine as RME. But IPM must not if SSH/SSL shall be used. What else?
Thanx
Georg
